Brief Description: Drill and Install Bracket for Engine Control Cable
Next I wet sanded the bracket for the engine control cables to match the wet-sanding that was done on the panel. Then I used a unibit to enlage the holes for each of the cables. My setup will be carb heat, throttle, mixture, and open. These can easily be converted / shuffled to add a prop control if I ever decide to go with a constant speed prop down the road. Once the holes were enlarged and deburred I screwed the bracket to the bottom flange of the panel.
Panel bracket for engine control cables drilled and deburred
Engine control cable bracket screwed to bottom of panel
