Brief Description: Temporarily Install Panel; Mark Subpanel for Cutou
Moving right along from the engine to the rudder stops back up to the panel...
I temporarily installed the panel so I could mark where I needed to make holes in the sub-panel for cable pass-throughs. I also plugged all of the Approach Systems harnesses/cables into the hub. There sure are a lot of wires / pig-tails that need to be routed and connected to various things.
I need rectangular cutouts for the two Dynon units, the transponder, and the audio panel. I also need a round cutout for the transponder antenna cable.
Panel temporarily installed to mark subpanel for avionics cable cutouts
Panel temporarily in place and Approach Systems harnesses connected to hub
