I'm not sure I will stick with the white panel. Our plan was to prime the parts today and then use a white Dupont Imron topcoat when we got back from Oshkosh. Seeing how shiny and bright the panel is with just the epoxy primer, I think I'll actually go with a gray panel. Also, the panel has a fair amount of orange peel, we think from the HVLP gun. We'll probably end up using the pressure pot for the gray since this atomizes the paint better.
