Brief Description: Drill Hole for Low Voltage Light; Trim Bracket
I decided to locate the amber low-voltage light that came with my B&C Specialty linear voltage regulator also in the upper portion of my panel along with the trim indicators and ELT switch. I drilled a 15/32" hole for this and deburred.I also had to trim/round out the upper left panel attach bracket on the fuselage to provide clearance for the ignition switch.
Hole for low voltage light drilled
Left panel bracket trimmed/rounded to allow room for the ignition switch
