Dan's Web Site
Date:  2-12-2006
Number of Hours:  1.25
Brief Description:  Notch Rear Window and Install for Drilling
I jumped back to working on the aft window next. It's a tight fit trying to coax the plexiglass under the top skin all the way around the aft edge. The initial fit wasn't too bad. I needed to notch the lower front corners to fit around the large rollbar attach brackets. I also had to notch the aft edge approximately 3" in length to fit around the top center support channel where it attaches to the F-706 bulkhead. Once the notches were made, the rear window fit perfect!
Need to notch the front lower corners and around the top aft center support channel
That's better.  No gaps anywhere.
