Brief Description: Cut Aft edge of Rear Window; Debur
I started today by cutting the aft edge of the rear window. This was a very long cut. My compressor ran constantly and is blistering hot. This was a rather awkward cut given the final shape of the rear windown. I had to use a lot of duct tape to keep things stable. As with all cuts I immediately deburred the aft edge with the Avery plexiglass scraper to avoid any possibility of a crack. Also, keeping the basement between 85 and 90 degree's helps in this regard as well. I think I'm starting to lose some weight in my basement sauna.
