Brief Description: Trial Fit Canopy Again; Mark for Next Cuts
Once the Big Cut was done and all of the edges were polished again, I installed the front part of the canopy back onto the frame again. I then marked where I wanted to make the next series of cuts, which were basically the front corners as well as the two sides. Then it was back to the sawhorses to tape the outlines of the cuts that I will make another day.
Front canopy installed again, left corner and side marked for the next trim
Front canopy installed again, right corner and side marked for the next trim
