Brief Description: Tape for the Big Cut; Mark Rear Window for Next Cu
Once I had the next set of cut lines marked on the canopy, I moved the plexiglass back to the sawhorses. I then taped along both sides of the Big Cut line. I also traced an offset line about 1-1/4" back from the rear window outline and marked DO NOT CUT all along the original line. I'll save the Big Cut for another day.
