Dan's Web Site
Date: 9-18-2005
Number of Hours: 2.00
Brief Description: Match Drill Top Skin to Fuselage
The first thing that I did today was match drill the top skin to the sub panel, longerons, ribs, and firewall. I had to have Daisy and Heather come down at various times to hold the ribs in position so the centerlines showed through the holes in the skin while I match drilled the initial holes. Everything came out great. Once the skin was match drilled to everything, I unclecoed the left side and reached in and drilled the F743B attach angle for the center rib to the firewall. The top skin was then completely removed for deburring and dimpling.
Top skin match drilled to subpanel, longerons, ribs, and firewall
F743B drilled to firewall
