Brief Description: Match Drill Forward Fuselage Structure
The next step was to match drill all of the forward fuselage components. I also drilled the F743B attach angle to the F643-1 center rib only. It will be drilled to the firewall after drilling the rib to the top skin to make sure it is positioned properly first.
