Brief Description: Drill F768C Outboard Seal Support Angles
Today I drilled the F768C seal support angles to the outboard sub panel sections. Nutplates were then installed on the panel end of each rib. The outboard subpanel sections were then clecoed to the ribs. The outboard assemblies were then clecoed to the fuselage. The center subpanel section was then inserted between the two outboard sections and everything clecoed together.
F768C seal support angles drilled to outboard sub panels
Nutplates installed on panel end of ribs
Outboard and center sub panel sections clecoed to fuselage
