Brief Description: Fabricate F768D Seal Support Angles
Today I fabricated the F768D seal support angles. These angles had to be notched similar to what was done on the panel support angles. This allows the angles to bend around the top perimeter of the outboard subpanel edges. First I marked and drilled all of the rivet holes. Then I drilled 1/4" holes along the vertex of the angles between the rivet holes. I then used tin snips to complete the notches.
