Dan's Web Site
RV-7A
Assembly
6-8-2011
Bolt Rudder Cables to Rudder; Charge Battery
Once the rudder was installed I bolted the rudder cables to the rudder horn using finger-tight castle nuts on the bolts along with cotter pins.
I also pulled out the boards that I was using for chalks and dug out my air gizmo chalks and wedged them against the tires instead.
My final task for the day was to hook the charger back up to the battery.
Right rudder cable bolted to the rudder
Left rudder cable bolted to the rudder
Battery charger hooked up and air gizmo chalks in place
RV-7A Home
2363
Ailerons
Assembly
Baffles
134
110
Big Dig
Brakes
Canopy Frame
144
152
Cowl
68
74
Electrial
120
96
96
Elevator
Filtered Air Box
Flaps
Forward Fuselage
460
Gear
Hangar
Hardware
Horizontal Stabilizer
Left Aileron
Left Flap
Left Fuel Tank
Left Wing
90
117
Panel
Photo Shoot
25
Right Aileron
Right Flap
Right Fuel Tank
43
60
Right Wing
84
Rudder II
Seats
Service Bulletin: No
Spinner
Systems
Training
Vertical Stabilizer
146
