Brief Description: Drill Canopy Frame to Attach Angles
The next step was to drill the lower ends of the canopy frame to the F731C&D attach angles. I drilled both inboard holes on each end first. The forward two outboard holes were then drilled using the prepunched holes in the side skins as a guide. The aft two outboard holes do not get drilled through the skin so I had to remove the canopy frame and attach angles from the fuselage and drill these on the bench.
Left inboard and forward outboard holes drilled in frame / angles
Right inboard & forward outboard holes drilled in frame / angles
Aft holes drilled in outboard attach angles and frame
