Today I wiped off all of the excess Wonder-fil pinhole filler and vaccumed the canopy before priming everything with SW 988 rattle-can primer. I guess I didn't fill / sand as well as I had thought, particularly along the front corners of the frame. Lots of compound curves and materials converging at these points. Much easier to see the problem areas now that everything is one color. I could leave this for later but why not take care of it now while the canopy is masked off and in the paint booth. Definitely need another layer of Rage filler on the front corners, one spot on the targa strip, and one spot on the right side where the "ear" or tab that holds the plexiglass in bulges out.
