Brief Description: Drill / Bolt Latches to Canopy Frame
Moving away from fiberglass work again...I had installed the original canopy latches a few weeks ago but they were drilled to high and therefore made for a very tight latching mechanism. Too tight actually so I had ordered two new steel latches. I used the old latches as a drill guide for the new latches and just offset the pieces by 1/16" to lower the holes on the new latches. This worked out perfectly. I bolted the new latches to the canopy and the latching mechanism works just fine now.
