Dan's Web Site
Date:  8-26-2006
Number of Hours:  1.00
Brief Description:  Mirco Canopy Corners; Mirco Right Elev Lead
I removed the canopy and layed it upside down on a tarp on the floor. I decided to reinforce those thin fiberglass front corners. The first thing I did was sand all of the primer off the inside flanges of the canopy rails as well as the side skins/fiberglass with 40 grit. I vacuumed everything and cleaned with acetone.Next I mixed up a small batch of micro and used a small popsicle stick to make a nice fillet along the gap between the flange of the canopy rails and the side skins/fiberglass. This will provide a smooth transition for the fiberglass as it bends L-shaped along the rails and skin.I also placed some duct tape on the aft side of the right elevator lead counterweight and then filled the large lightening holes with micro.
Right corner filled with micro fillet
Left corner filled with micro fillet
Right elevator counterbalance lead filled with micro
