Dan's Web Site
Date:  4-1-2006
Number of Hours:  0.75
Brief Description:  Drill Forward Strut Brackets to Frame; Tap Bracket
I had ordered both #27 and F drill bits and corresponding tap's about a week ago. Since they finally arrived I decided to finish up the forward canopy strut mounting brackets. I measured, clamped, and drilled the brackets to the frame and then used the holes in frame to drill the C-702 top skin. The C-725 brackets were then tapped using a 5/16X18 tap.
Front strut bracket clamped and drilled to frame
Match drill C-702 skin to frame
Tap forward canopy strut bracket
