Today I did a little more deburring and edge prep of the canopy frame. I also countersunk the channels for the splice plate and hinge tabs. I alodined the mating surfaces and then riveted everything together.Although I don't have a picture of this, I clecoed the top skins back onto the fuselage and the canopy frame. I then installed the frame to check to see if the top skins would have enough clearance as I rotated that frame up. Nope. The edges of the two skins hit in the center. I'm not sure what I'm going to do to fix this yet.
