Brief Description: Redo Left Brake Line from Fuselage to Caliper
Repeat for the left brake line...
I'm very glad that I decided to stick to the plan's with the brake lines. No chance of damaging the gear legs from steel-braided lines, the aluminum lines are lighter, and the calipers have no inward or outward pressure on them from the lines themselves so they don't cause the calipers to rub on the rotors.
New 1/4" aluminum tubing brake line with loop connected to left caliper
New 1/4" aluminum tubing brake line connected to fuselage fitting
New 1/4 aluminum brake line on aft side of left gear leg & secured with vinyl tubing & electical tape
