Brief Description: Wrap Low Pressure Lines with Spiral Tubing
I'm not sure if this was really necessary but I decided to wrap the low pressure brake lines with plastic spiral tubing from the master cylinders up to the overhead rudder pedal tubes to prevent chaffing on the lines. I'm not sure if I'll keep this in place or not. The lines are very smooth and durable without the extra protection and perhaps the spiral tubing will actually be detrimental to the steel rudder pedal tubing. Still undecided...
Left brake lines protected with plastic spiral tubing
Right brake lines protected with plastic spiral tubing
