Brief Description: Fabricate New Parking Brake Valve Bracket
Today I fabricated a support bracket for the parking brake valve. I used a piece of 0.063 aluminum sheet and mounted a large angle on one side. I was able to download the specs for the Matco valve which indicated a 45 degree range of arm travel between the on and off positions. So I cut a "V" in the side angle matching these specs in order to provide the appropriate stops.
