Dan's Web Site
Date:  6-2-2005
Brief Description:  Finish Right Tank Vent; Trim Brake Pedal
Today I finished fabricating and installing the right fuel vent tubing. This definitely went quicker than the left side, especially since I located the hole through the fuselage skin better to allow more room for the bulkhead fitting. Once this was done I decided to pull out the brake pedals and trim the lower ends of the vertical angles. I originally cut the ends horizontal but after looking at several completed RV's I think the tapered ends look much better. Mine are tapered now.
Right fuel vent tubing complete
Brake pedals with the lower ends of the vertical angles trimmed
