Dan's Web Site
Date:  7-5-2006
Number of Hours:  1.00
Brief Description:  Rivet Angle to Andair Fuel Valve Cover
There was about an 1/8" gap between the fuel valve cover and the leading edge of the top plate that the valve is fastened to. This plate came with a large tab angled upward that was designed to hold the manual elevator trim knob. Since I am going with electric trim, the plans said to cut this tab off. Unfortunately, this left the gap along the top leading edge next to the cover. I decided to fabricate and rivet a light 0.040 piece of 3/4 x 3/4 angle to the top forward edge of the cover box to fill the gap. The top plate has a much nicer finished look now.
Andair fuel valve cover with angle clecoed to upper front edge to cover the gap
Andair fuel valve cover with angle riveted to upper front edge to cover the gap
