Brief Description: Secure Right Side Primer Lines with Adel Clamps
I then secured all of the primer lines on the right side of the engine with adel clamps. The final line from the gascolator to the brass T fitting on the back of the engine has a service loop to absorb vibration since this is the line that will flex the most when the engine vibrates at one end while the other end at the gascolator remains rigid on the firewall.
Brass T between Cyl's 1 & 3 secured with adel clamp
Brass T at back of engine secured with adel clamps
Primer line from the gascolator with service loop connected to brass T fitting at back of engine
