Brief Description: Install Right Side Cylinders 1 & 3 Brass T Fitting
The final step for today was to connect the cylinder # 1 and #3 primer lines to a brass T fitting and then from there to a stainless steel line that wraps from cylinder #3 around the back of the engine to connect up with the line from the left side cylinders #2 and #4. The final connection will be from the T fitting at the back of the engine to the electric valve on top of the gascolator.
Cylinders 1 and 3 stainless steel primer lines connected to AN4022-1 primer discharge nozzles
Cylinders 1 and 3 primer lines connected to brass T fitting
Left and right side primer lines join up in the back via a brass T fitting - to gascolator
