Dan's Web Site
Date:  3-2-2007
Number of Hours:  1.00
Brief Description:  Install Left Main Wheel on Axle; Drill / Cotter Pi
As with anything, the second time is always much easier than the first. I didn't have any problems installing the left main wheel after dealing with the right wheel / axle yesterday. No broken bits today. I used a new #40 bit to get things started and that did the trick. Once the #40 hole was through the steel axle, it wasn't a problem enlarging it to #30 using the pre-drilled holes in the nut as a guide. I still had to clean up the threads a bit with a needle file.
Once the hole was drilled I installed the bearings, spacers, wheel, and axle nut. After torqueing the axle nut / aligning the holes in the nut with the holes in the axle I inserted the cotter pin and bent the ends around. I'll have to order a bunch of these cotter pins so I'll be prepared for any future maintenance that may be needed on the wheel pant brackets, brakes, wheels, tire, etc.
Left main wheel on axle with cotter pin installed
