Dan's Web Site
Date:  10-25-2003
Number of Hours:  1.00
Brief Description:  Rivet Trailing Edge
I think I like the double flush riveted trailing edges over the folded trailing edges. This technique was much easier than everyone on the RV-List made it out to be and the final result is a nice, crisp, straight trailing edge. The first thing I did was remove all of the extra proseal from the rivet holes using Acetone. Then I used the hand squeezer to paritally set all of the trailing edge rivets, starting with every 10th hole or so and working back and forth to keep everything straight. Then I broke out the back riveting plate and the rivet gun with a mushroom set and finished setting all of the rivets. The shop heads of the double flush rivets turned out great and the trailing edge is straight as an arrow.
Remove proseal from rivet holes - Acetone
Back rivet the partially squeezed rivets
Nice straight double-flush riveted trailing edge
