Brief Description: Finish Riveting Skins to Ribs and Spar
After the skins were riveted to the spar it was time to rivet them to the end ribs. This was tough because of the close quarters. I ended up using pop rivets in the aft-most two holes on each rib. Everything is riveted together now with the exception of the trailing edge which needs to be pro-sealed first to keep everything straight while riveting.
