Brief Description: Cut Hole in Rudder Bottom Tip for Lights
Next I marked the bottom rudder fiberglass tip for the position/strobe lights. I used a unibit to make a 3/4" hole and then a sanding drum in the dremel to enlarge the hole to 1-1/8".
Rudder bottom tip drilled for position/strobe lights
Hole drilled/sanded in rudder bottom tip for position/strobe lights
