Dan's Web Site
Date:  3-20-2005
Number of Hours:  0.50
Brief Description:  Drill / Split Center Support Block
On to the flaps... I clamped the center support block to the drill press table and drilled the two mounting holes. I then used the bandsaw to split the block so it can be slipped around the actuator arm. I then positioned everything in the fuselage, clamped the center support block in place and used the holes that I just drilled as a guide to drill the holes in the floor and flange of the tunnel rib.
Drill center flap support block
Cut center flap support block in half
Clamp and drill center support block to fuselage
