Today I worked on the F741 tunnel cover. The side angles required some work to get them shaped according to the plans. I actually did thing a bit backwards. I should have drilled everything in assembly with the fuselage. Instead I drilled everything separately. I have a bit of problem fitting the assembled cover over the tunnel. I have to spread the angles out just a bit in order screw the cover down to the floor. It's doable but I'd rather have it perfect. Not worth ordering new parts for though.
Fabricate F741A angles and F741B sheet, drill and countersink
