Brief Description: Rivet Seat Hinges to Floors; Edge Prep
I used the C-Frame to rivet the hinges to the seat floors. This worked out fairly well but I think AN470 rivets are overkill here. I kind of wish I had used LP4-3 blind rivets instead. It would have saved me some time and I think the hinges would have layed a little flatter. Using solid rivets distorted things a bit,,,the hinges are slightly rippled. Oh well, I followed the plans. The next thing that I did was all of the edge prep work on the seat floors. Everything was then cleaned with acetone and then alodined along overlapping areas.
