Once the fuselage was completely level, I clecoed the aft deck to the spacers and longerons and then drilled everything using the holes in the aft deck as a guide. Once the aft deck was drilled and clecoed to the longerons, bulkheads, and spacers, I checked everything again to make sure the fuselage was still level. Yep, no twist! Whew.
