Brief Description: Cleco Floor Stiffeners;Rivet to Brackets
I clecoed the center 2 floor stiffeners in place and riveted them to the forward and aft brackets on the firewall and F704 bulkhead respectively. I was able to squeeze all of these rivets but I had to unscrew and remove the outer 2 brackets on the F704 bulkhead in order to provide room for the squeezer. Also, there just wasn't enough room to squeeze or shoot the aft-most rivets on the F704 bulkhead brackets. I ended up using blind rivets here. Once the 2 center floor stiffeners were riveted to the firewall and bulkhead brackets, I reinstalled the outer F704 bulkhead brackets and clecoed the outer 2 floor stiffeners to the bottom skin.
Center two floor stiffeners riveted to firewall brackets
Center two floor stiffeners riveted to F704 brackets
