Brief Description: Rivet F796C Bulkheads to Longerons
Before clecoing the bottom skin to the forward fuselage I riveted the bottom flanges of the F796C vertical bulkheads to the lower longerons. I was able to squeeze these rivets. The final thing that I did today was drill 2 holes in the rudder pedal center support bracket. These are needed for the brake lines that will connect the left and right sets of brakes.
Forward fuselage clecoed together for the final time
Rudder pedal center support drilled for brake line bushings
