Brief Description: Trim F704 Flanges for Main Gear
The next thing I drilled was the bottom tabs of the forward vertical bulkheads to the lower longerons. I then used a sanding drum in my dremel tool to trim back the flanges of the F704 forwar bulkhead for the main gear using the cutouts in the skin as a template.
Drill bottom tabs of forward bulkheads to lower longerons
F704 bulkhead flange needs to be trimmed here for main gear
F704 flanges trimmed for gear using the skin as a template
