Brief Description: Center Section: Bolt Ribs, Debur Skin
Today I bolted the seat ribs to the upper and lower flanges of the aft center section bulkhead. These bolts were torqued and sealed. I then used the soldering iron to remove the plastic from the inside of the center section bottom skin and deburred the rivet holes.
Bolt seat ribs to upper and lower flanges of center section
