Brief Description: Center Section: Unibit F704 - Battery
I enlarged one of the wiring holes in the forward and aft F704 bulkheads for the optional aft battery installation. These will unlikely be used since I will need the weight of the battery on the firewall since I will be using a smaller engine. I thought I would make the optional changes for an aft battery installation in case I change to a larger engine someday way down the road. It's easier to make these preparations now than it would be after the plane is finished.
Forward section of F704 - one hole enlarged to 3/4" for battery
Aft section of F704 - one hole enlarged to 3/4" for battery
