Brief Description: Aft Side Skins:Prime/Dimple Rudder Cable
I almost forgot to drill, debur, and dimple the hole in each side skin for the rudder cable bracket. I took care of this and then used some Acetone to clean the insides of the side skins along the rivet holes so they could be primed. These are the first skins that I primed. I'm not sure why I decided to do this now but it couldn't hurt. I left the plastic on the rest of the inside skins to mask off the areas that I didn't want to prime. I just wanted to catch where the J-Channel's and bulkheads would be attached.
