Brief Description: Match Drill Aft Fuselage Debur Left Skin
I match drilled the aft fuselage today with the exception of the F706 bulkhead as noted in the instructions. This will be match drilled once the center section is joined to the aft section. Once everything was match drilled, I started the prepping everything. I started by removing the left side skin, removing the plastic along the rivet holes, and then deburring both sides.
Right side view of aft fuselage - match drilled
Left side view of aft fuselage - match drilled
Left side skin removed, plastic removed and holes deburred
