I washed and primed several of the F706 bulkhead parts today. While waiting for these parts to dry in between washing and primer coats, I clecoed the F707 and F708 bulkheads together and match drilled them.. I then used a Unibit to drill the 5/8" holes for the rudder cables and wiring runs.
F707 bulkhead clecoed and drilled; Rudder/wire holes drilled
F708 bulkhead clecoed and drilled; Rudder/wire holes drilled
