I pulled out the C-Frame tonight along with a bunch of foam and started hammering some dimples. I was able to dimple the relatively flat bottom surface by myself but I needed David's help to dimple the curved top skin. David helped hold and gently rotate the skin perpendicular to the dimple dies while I hammered away.
Bottom of skin dimpled
I needed David's help to dimple the top of the tank skin
