Brief Description: Countersink Rear Spar; Prime Front Spar
Once all of the dimpling was done I countersunk the holes on the rear spar where there were reinforcement plates installed. It was not possible to dimple these areas. After finishing up the rear spar prep work I primed all of the front spar rivet and screw holes with Rustoleum using a brush.
Countersink the rear spar where the reinforcement plates are
