Brief Description: Insert Wing Tip Rib; Mark Aft Edge
Tonight I worked on the right wing tip rib. The first step was to slide the rib into place and adjust the position fore and aft such that it would fit snug without distorting the shape of the fiberglass tip and then mark the trailing edge of the rib on the fiberglass.
