Brief Description: Run Wiring Conduit; Cleco Bottom Skins
The next step was to run my wiring conduit through the main ribs. This was rather difficult until I discovered if I stretched the flexible tubing by pulling on both ends, it reduced the diameter of the tubing enough to easily fit through the holes that I had drilled in the main ribs. Once the pressure was released, the conduit fit snuggly where it was posititioned. I left ample conduit hanging out each end of the wing to be sure I had enough to work with down the road. The next thing I did was cleco the bottom main skins to the wing. I primarily did this for storage purposes. I am in no hurry to close up the wing until I am sure everything is complete.
Stevie posing against bottom view of wing
Wiring conduit routed through wing
Bottom skins clecoed in place for storage purposes
