Brief Description: Debur / Dimple Bottom Main Skins
I deburred and dimpled both of the bottom skins today. I did not dimple the 4 holes in the overlapping corners of the skins that will fit up against the tank skins since I wanted to taper these corners first and it will be much easier to do this without the dimples. These holes will get dimpled after the corners are tapered.
