Brief Description: Debur/Dimple Leading Edge Ribs - Prime
After completing the prep work on the leading edge / fuel tank coupler plate I deburred the edges. Then it was on to the deburring and dimpling all of the leading edge ribs. Once this was done, I washed and primed the Z brackets, the coupler plate, and the inboard leading edge rib.
Completed leading edge/fuel tank coupler plate
Deburred and dimpled leading edge ribs
Z brackets, inboard leading edge rib & coupler plate all primed
