Brief Description: Level Jig and Cleco Top Left Main Skins
I spent this evening squaring up the jig. This was fairly easy using the leveling nuts on the steel base plates on the posts. Once the posts were level, I replaced the wood on the cinder block with my hydraulic car jack. I strung a piece of fishing line from end to end along the front flange of the front spar. Then i raised the jack until all of the holes were centered along the fishing line. Worked great! Once everything was squared up, I clecoed the top main outboard skin onto the left wing. This was very exciting and is really starting to look like a wing. But it also is starting to look very BIG in my little basement. It will really be a challenge getting this out of the basement a couple years down the road. Definitely need a larger basement window!
Bottom view of left wing - top outboard skin clecoed on
Top view of left wing - top outboard skin clecoed on
