Brief Description: Remove Rudder; Drill Upper Front Spar Ho
I removed the rudder today and drilled the upper row of rivet holes on the front spar using the prepunched holes in the attach plate as a guide. I couldn't reach these holes to match drill them while the rudder was mounted to the fuselage.
Rudder removed and upper front spar holes drilled to plate
